Solidworks wire routing
raghu4414
Facing a typical problem with solidworks routing,
issue- during routing the wire details such as OD and minimum bend radius was given and saved in xml( this xml was saved in PDM linked folder
also the xml was saved in excel format too. the peculiar problem is the OD and min bend radius values changes once it is closed and opened , for example OD is 3mm (units set to mm) and min bend radius is set to 12mm, once closed and opened the values showing up are 0.003 and 0.012 respectively.. but the values remained same when opened the excel format..
now if I apply the wire details to the cable created in the model which is in mm format,, the dimension i get for the wire is 0.003mm .
one solution which I checked was to repair the solidworks but to no avail..
CAN ANYONE PLEASE HELP WITH A SOLUTION..
