Surface representation with out shading
Status
Not open for further replies.
B
Baeddan
How can one stop the surface representation in such a way in V5, so that as in V4 ISO paramters are indicated. Can I specify the ISO parameters?
R
Rambo
The shading modus can be switched off so that edges become visible and also facets are possible. As far as I know ISO parametric representation is not there. Within the surface range would be nevertheless meaningful or necessary.
Thanks.
You can customize the Render Style as Rambo suggested to turn off the shading and just see the edges of your surfaces.
Or, if you have the GSD or Freestyle workbenches, there is a command called APPLY DRESSUP that adds isoparametric curves to surfaces, with or without shading.
Status
