Text Font
Benard
I want to know whether there is a way to change the text style so that when I use either Multi line text or text used for a detail should be the same instead of changing each one manually.
Thanks in advance.
Not quite sure which way your going
You can set each subsequent text be presetting your formatting before you start typing
Thats all in the text window
If you already have everything placed in the drawing and you want to change the properties of all, then youd use the match properties tool.
Create a text or mtext in the drawing with the style appropriate for the detail and then another text or mtext with default settings, now drag each text one by one to tool palette, then use the tools as needed. This way you can create multiple tools in tool palette referencing different text style.
With regards,
