C
CADMiester
This is from the Tips & Techniques section of the VX CAD/CAM online help.
CAUTION: You cannot activate two files during the same session that have the same name but reside in different directories. You have to clear the file edit already associated with the active session with the Clear File Edit command before you can open another file with the same name. If you want to save any changes made to the file during the active session use the Save File command first.
CADMiester
CADMiester
