Is anybody know where can I find the Knowledge Fusion Tutorial from? I would like to use this for updating my part automatically in UG when any parameter is changed. THanks.
You can download knowledge fusion study material from below login http://www.scribd.com/doc/6539345/Knowledge-Fusion ,but u need customized file to work out sample Exercise’s. you can learn basics from this material
Material name: UG/ Knowledge Fusion for Designers
Version : V18
By using knowledge fusion you can't change parameters directly, but you can make it through ug_expression
Just i created one sample program for your reference
in that program i created 4 lines instant of doing "ug_curve_intersection" and "ug_curve_join" to make it simple, instant of doing bounded plane i made extrude and extracted faces from the Feature, Because i understand through your dfa code&mail , that you need to know how to find area of a surface. Please go through the below code
in the file
Attribute ‘value’ i used to assign value for line and ug_feature_askFaces Function used to extract face from the body, and ug_face_askArea Function used to find the area of the required face
In the attribute “Area” you can find Area of the Given Face (in give program i taken 6th Face)
I hope It's sufficient to clear your drought . If any dought Please Revert Back, If you know any vacant Regarding unigraphics Knowledge fusion please Forward it to my mail ID.
Hello friends, I apologize in advance for my English. Please help us to understand the syntax in KF. Trying to make sweeping using class nx_swept on previously created lines. dfa-file being tested for syntax, but when I run nothing built. Who knows what is my fault? The code is given below. I would be extremely grateful if somebody will share examples of operating codes for nx-classes in particular on nx_extrude. (Child) stenka: {
Class, nx_swept;
Section_list,forward,line_1:;
Guide_list,forward,line_9:;
Spine_Tolerances,{0.00095,0.001,0.01};
Scaling_Method_Scale_Option,Costant;
Orientation_Method_Orientation_Option,fixed;
Orientation_Method_Align_type,Parameter;
Interpolation_Option,None;
Body_Preference_Body_Type,solid;
Preserve_Shape_Option,True;
Suppressed,False;
Section_Location,anywhere_along_guides;
