ug question, very urgent
prakash
How to create Variable pitch helix in unigraphics with following specification?
say
Start pitch=123mm
end pitch =200mm
diameter=126mm
length=1000mm
Regards
Prakash
SDETERS69
Are yout talking about getting an curve you can sweep around or what?
What is your goal I can get you a curve from I-Deas with these numbers
I think you can set up law curver in UG to get this type of curve
Also Can you do a revolve with translate with a change in radius
prakash
Varible pitch helix
hi ,
i have attached file of the component for your referance.
UG%GURU
Law Curves are your friend
Law curves is definitely the way to do this.
Hint: t is your variable, its range is 0 to 1, divided into increments.
