unigraphics welding ..do help
N
nitheshshetty23
i am using UG Nx2 version and am having the welding module , but only fillet weld works correctly..i want to know is there any help directly on this issue who can help me use welding in a proper way... i tried many times to use these welds but couldnot do it correctly ...
guidance awaited on this issue.
thank you.
HI,
After selecting the weld symbol toolbutton a toolbar appears next to the Selection Filter. There is a drop-down to select all-around or you can use the Leader tool. The problem is that you can not add the all-around once the weld is created, you have to delete and re-create. There is no option for all-around on 'Edit Leader'. I do not understand why this is or why it is not in the weld dialog box..
Thank you....
