Update error in Multisection solid
Hard to say what the exact problem is without seeing the entire graphic (the pop up error is blocking most of the model).
Check the coupling (green curves) and the section arrows.
If you need more help, please attach a picture of the Multi-Section Solid just before clicking the OK button
nocturne27
IMO, sometimes when you select the sketches, it varies on the direction of the closing points. I think thats why before you have the problem and now you doesnt.
also when using that command, it's convenient to have the same points on each sketches. you can add one so that those points can be used on coupling and etc.
Sometimes I try to use different options on the "coupling" tab. just make the "tangency then to curvature" into "ratio"
Its a quick fix, but it does not work every time.
