Use several times the same assembly with differents parameters
bendesarts
I have a assembly composed with several assemblies : branch1, branch2 ... These assemblies are made with geometry but with some difference for some dimensions.
I want to add several times the assembly "branch" but i would like to be able to change some dimensions (which have been parametrized) of one branch without changing the dimensions of the others branchs.
I believe it can be done with "document model".
Have you some ideas so as to use several times a assembly and keeping the possibility to change some parameters indepently from the others assemblies.
If the solution must use "document model", have some informations about that ?
Thanks a lot for you help.
