V5 Viewer
L
lspieler
Hi All,
Can anyone recommend a 3rd party viewer for Catia V5 .CATDrawings. I need our shop to have view only privileges for native .CATDrawings without having to maintain a second data set also the ability to print them from the shop floor.
Any suggestions or comments would be greatly appreciated.
Larry Spieler
Tool Design Engineer
Pennsylvania
The company I currently work at uses eDrawings, which seems to work pretty good.
I would think Acrobat Reader would be a good solution as well.
L
lspieler
MrCATIA,
Thanks for your swift reply. But the main thing i am trying to avoid is having to maintain a second data set. Although eDrawings and or Acrobat Reader are an option especially on the pocket book, I would have to save literally thousands of drawings to a all together different format and maintain that data set also each time changes are made to a drawing.
Am I correct in that assumption? I am just starting to explore my options so my knowlege of different methods and softwares for doing this is minimal. But believe me when I say that your input and knowlege are greatly valued.
Larry Spieler
Pennsylvania
Yes, both of my suggestions do require a conversion and a second database. There are pros and cons to this.
I haven't used the DMU Navigator for awhile - does it work with drawings?
Hopefully someone else will have suggestions for you. Or maybe you can find a solution at the COE conference.
L
lspieler
MrCATIA,
You know I'm not familiar with the DMU product. I have checked out COE and Catia Eng-Tips there were mentions of Cimmetrys Autovue, Actify and Solidview which I have looked into a little bit so far and was somewhat impressed with the Autovue product. It has been a couple of years since I have been down this road and did research on different viewers. I'll keep on looking and probably get a rep. in to talk to us.
Thanks for your input,
Larry
P
pod2487
DMU viewer will view drawings. The most common use of DMU viewer is by non-CAD users in an Enovia PDM system, the viewer is 3D and 2D with the ability to section and markup but not authoring.
