Version
S
srinivas_mvv
working with multiple Release levels
Can any one tell, How can we open higher version parts in lower version parts.
For example:
I would like 2 open part which is created in R16 into R13.
Do n't say that not possible.I heard that it is possible.
Thankx in advance
spider007
you can try batch menagement from windows start menu and use "downward compatibility". I think you can get to same thing from catia using "tools - utilities", not sure, nowhare near catia right now....
Good luck with that, i hear it can be a pain in the azz
Srinivas,
CATIA V5 is "upward compatible" only. If you are running R16, you can open any CATIA file that was saved at R16 level or lower. So you can open both of your parts; R16 and R13.
But, if you are running R13, you can only open any CATIA file that was saved at R13 or lower. You can open your R13 parts, but you'll get an error message when you try to open the R16 parts.
As you were told, it is possible to open the higher level parts, but first you have to "convert" them to the lower level by using the Downward Compatibility utility program. Tools + Utility + DownwardCompatibilty is the program, and it's fairly easy to use. However, the utility strips out the history and only provides a "dumb" solid copy that cannot be editied. So don't replace or delete the R16 part after it's been converted.
I've been told that it's a good idea to run the CATDUAV5 utility (DATA Upward Assistant) whenever upgrading to a higher release level. I've never had a problem with just opening lower level parts and saving them to convert to the higher level, but that's what was suggested to me.
In a perfect world, everyone would use the same release level :)
