Want to add flat text
comet
Hi. I want to add flat text to an object.
Like on a chip -- I want to print 'Intel 16GB'
So I draw the chip on a circuit board, (two objects), then I want to print FLAT text on one of the objects.
So far I only found tutorials that either extrude or cut the text.
I want the text to be visible when flat, as if painted on.
And when it is flat, I want it white so it would be visible on grey background.
How to change the color?
Something like a 'Text Box' in Microsoft Word would be good.
I believe you are asking to split the face, in which case there are two ways both require a sketch with your text in then either...
Insert - Features - Wrap and choose scribe (this is better if on a curved surface)
or
Insert - Features - Curve - Split line
this will split the face allowing you to colour.
to colour, select a face of your text and use the colour option
