Hi, I'm new to the forum
I need to animate the following three components for a presentation in a few weeks time. The stick-like plunger components moves inside the stationary brown cylinder and displaces oil inside the green component which causes the green component to expand as shown.
Basically - The silver plunger and the green component have different stroke lengths.
The green component is basically made from a single revolve command. I've used an "Equivelent Dimension" to allow me to change the pitch of the ribbed section of the green component.
What I want to do is have a measure between the silver plunger and the brown cylinder > Divide that by 15 > and set that to the Equivelent dimension on the green component.
This youtube video shows how you can set the distance between 2 planes as the length of a helix - causing a deflecting spring.
If I find the Equivelent Dimension in the tree and click "edit Formula", CATIA won't allow me any references to measures/anything - "....cannot be used in this context"
Is there a way around this? Anything I can do?
Any help much appreciated
