Follow along with the video below to see how to install our site as a web app on your home screen.
Note: this_feature_currently_requires_accessing_site_using_safari
Well Part B and Part A belong to different CATProduct , then it is not able to creat ref between them?The "design in context" warning message means you are not working with the CATProduct assembly that was used when other references were created. You should open that assembly, which will put you in the correct contextual mode.
Are you working within an assembly?
I also found the refs between other parts are useless and parts turned to be brown from green, what is wrong?The "design in context" warning message means you are not working with the CATProduct assembly that was used when other references were created. You should open that assembly, which will put you in the correct contextual mode.
With the Parts being out of context (brown icon), you cannot create external references automatically. But you can create them manually by Copy & Paste Special with LinkWell Part B and Part A belong to different CATProduct , then it is not able to creat ref between them?
Nothing is wrong - the parts have brown icons to indicate they are not opened in their contextual assembly.I also found the refs between other parts are useless and parts turned to be brown from green, what is wrong?
Thanks a lot , i got that . External references can only be built at the corresponding context!Nothing is wrong - the parts have brown icons to indicate they are not opened in their contextual assembly.
You can instance these parts in other assemblies with no problems. You just cannot edit them.
You can use the Edit + Links tool to find the Contextual assembly and open it, then the parts with have green icons and you'll be able to edit them as you want.
Or, you can Copy & Paste Special the elements from one part to another
MrCATIA,Nothing is wrong - the parts have brown icons to indicate they are not opened in their contextual assembly.
Do I need to practice this, if I'm making a product template using the document template creation in knowledgeware?To avoid circular loops of references, I like to put all of my "master geometry" into a special model that controls all the other parts. I also like to publish these master geometries. Then I make all the references with links back to that one Master Part.
(I've been using CATIA for a long time. I saw a V6 demo one time, but haven't had the opportunity to use V6 or 3DExperience yet)
Well, i have never ever seen the V6 version, it seems that the time gap between us is around 12 hours , so you are probably at east of USATo avoid circular loops of references, I like to put all of my "master geometry" into a special model that controls all the other parts. I also like to publish these master geometries. Then I make all the references with links back to that one Master Part.
MrCATIA, is there any chance you can elaborate more on doing the master geometry into a special model? is special model means a product in design tree that have the 'geometrical set' where different parts are built referencing to that 'geometrical set' only?To avoid circular loops of references, I like to put all of my "master geometry" into a special model that controls all the other parts. I also like to publish these master geometries. Then I make all the references with links back to that one Master Part.
