How to hide entity display tags?
support
This is a question from a previous post. We wanted to post it separately so other could find the answer more easily.
Question:
I have an assembly with lots of holes and the tags don't let me see, how do I hide them?
Click here to read the original thread from ffigueres.
http://www.3dcadtips.com/QABoard/fo...=Pro%2FE+Wildfire&order=time
Answer
» Question:
» I have an assembly with lots of holes and the tags don't let me see, how do I hide them?
:) In wildfire 2.0 go to View -> Display Settings -> Datum display. You can turn off the tags there (assuming you want to see the centrelines for the holes) or you can turn of the axis display, as required.
Thanks for using the Q&A Board!;-)
3DCADTips Q&A Board Support
Use Pro/E config...
:) You can use the Pro/E config file to set the display mode for various display entities such as:
display_axis_tags (yes/no)
display_coord_sys_tags (yes/no)
display_dwg_tol_tags (yes/no)
display_plane_tags (yes/no)
display_point_tags (yes/no)
Thanks for using the Q&A Board! ;-)
3DCADTips.com Q&A Board Support
In Pro/E 2001
The Support Desk has located another reply related to your post.
I'm in 2001, View > Display Settings > Datum Display.
Maybe this will work for you.
kuncar
Partner site, MCADCentral.com
