New person to solid works needing help
J
jonkers
As the topic says i am a new person needing help with solid works.
I have only been using it for a day or so and i got a grasp of the basics now and thought i would try and model something kinda simle that i thought i could do.
So i grabbed the thing closest to me and it happened to be the firing bolt out of my paintball marker.
Anyway i got what i consider something pretty good after a few hr's and was pretty happy with my first modeling attempt.
But there is one thing left to do and i can not for the life of me work it out.
I need to make an elliptical type shape dent in the side of it. I need it to gradually get deeper as it goes backwards along the bolt.
Any help[ with this would be great. If there is a tutorial that you know of that you could point me to or explain to me how to do it would be fantastic.
I have added a pic to try and show you what i mean.
Exactly what I was thinking... or just do a revolve cut. Establishing the axis could be tricky, though.
You could also try a filled surface. Make a sketch tangent to the face of the cylinder and draw the of the elipse. Next, on a perpendicular plane, add a sketch point to guide how deep the cut should go into the part; then do a surface cut. Check out the SUFRACES tutorial on the SW help menu for more info.
Or mabye an INDENT feature could work?
