section view bearings from toolbox in SW2006
O
Odisey
Can you help me how to make good section view of bearings in SW 2006 :-| (I mean that the section view does not look like standard bearing but like I draw ONE solid part)? Do I have to use an assemblies and how? Thank you!:p
support
Try this:
:) Go to the online HELP and type Section Scope. You can manipulate the section view as you want. This is for SW2005, but the same shold apply for SW2006. Let us know f this helps.
Thanks for asking the Q&A Board! ;-)
O
Odisey
Try this:
» :) Go to the online HELP and type Section Scope. You can manipulate the
» section view as you want. This is for SW2005, but the same shold apply for
» SW2006. Let us know f this helps.
» Thanks for asking the Q&A Board! ;-)
» 3DCADTips.com Q&A Board Support
Unfortnunately this not helps:( In the drawing SW recognises the toolbox bearing as a PART and FASTENER and hatches the balls also or nothing (if I mark exclude fasteners). For example what I need you can see the following pictures:
http://www.me.metu.edu.tr/me308/sample_eng_drwgs/gears/Lathe%20spindle%20gearbox.jpg
http://www.yc-forklift.com/assets/images/YCRB1ab.gif
G
gupta_9665
section view
well section scope shud work fine
or else do a thing
cut the section u need
and then add the hatch from the anotation toolbar to the area wr u want 2 show the hatching
check the file properties
if the property has a value is fastener, try deleting that one, but make it sure u keep a copy of that or u will delete the value from the original toolbox file
then i feel the bearing should behave like a normal part and hatching should come as reqd.
regards
Deepak Gupta
G
gupta_9665
section view
well dear i checked it today and find auto hatching is working fine even on toolbox components
check wot service pack u have
i tried it on SW 2006 sp 4.0
regards
Deepak Gupta
