Solid Edge and Complex Holes
conjoa
Whilst working in the Part environment I want to create a Conveyer Pulley system. It consists of a Conveyer Bracket, Pulley, Spindle, Washers and a split pin. The Pulley is supported by the spindle which rests between two holes in the bracket. The bracket is free standing, i.e it has a base with two arms, the arms are supported by ribs and the arms tops are cycliners with holes in them for the spindle, the Pulley sits between the two arms.
I want to make a hole in the top of one of the arms so as to place the pin in to hold the spindle in place.
The problem is that when I select the hole option I can not select the top of the arm because it is acylcinder, I can only select the two flat faces, I want to select the curved surface.
And to make the whole thing harder the hole is tapped...
Any suggestions???
conjoa
A small Claridication...
If I selct the hole tool and then parrallel plane, selecting the top plane and then using my mouse to select the top of the cylinder. I can draw the hole, but when I set the distance it gives me an error message saying that I have a zero thickness and that the resulting intersction is not supported.
Here is an Image of the part:
