Unbend or Flatten a Bent Sheet
M
matethreat
I am fairly new to unigraphics and I am attempting to flatten out a bent part so that I can determine it's shape before bending for profiling.
Can anyone out there run me through this process.
Thank You
I've not used it extensively but in my experience I have always created a 'TAB' of the unbent part then bent it into the form that I want. This allows you then to flatten the part back into the unbent form.
If you already have a bent part then I think there is a feature you can use to convert it from a solid model to a sheet model.
Not sure if this is really any help - ??
If you have created a solid and you want to unbend it is there a feature called Convert to Sheetmetal after you set sa different parameters ex.bend radius, neutral factor..ecc
Bye
Yes there is a feature that is called Convert to Sheetmetal. :D that converts a solid model in a Sheetmetal.
